Might as well make one thread instead of many. Here goes:
1. Seems like there's some power loss (i reached my transmission flush schedule) and there's noticeable lagg between shifts in all modes (manual/auto/sport) (sometimes)
2. I was slowing down and the gears shifted up and down a bit viciously (this has happened 2 times, once when slowing down and once speeding up)
3. When i turn heater/ac on there's this shaking rattle / whine noise
4. My left front tire has this rubbing / shaking sound when doing a slow 30-50 degree turn. (doesn't make sound at high speeds, but than again not many turns that would be same as maneuvering in a parking lot) It's almost like the tire is rubbing against inside fender, but isn't actually rubbing the inside fender.
5. When i am in manual mode and shift into 2nd gear, the gear doesn't catch, it sorta catches the gear and accelerates than it's like it bogs out for a second (even at low/high RPM) than it catches and stops doing it. (2nd gear is the only gear this does it) It's almost like i let off the gas feeling. But i keep foot exactly same position.
6. I was driving and i made a slow 10-15 KMH left turn, and i heard this sound like ... You know those old sirens the army used that you crank to make it sound? well you know when you would stop cranking it, it has a slowing down whine? It wasn't very loud but very noticeable on my car. It was loud enough to over power the mufflers/engine ambiance sound. It sounded like downshifting into lower gear, you know the sound the engine makes when slowing down at high RPM, but i don't think it was that, i wasn't in manual mode. Just sounded like it.
7. When i am backing up and i make a sorta hard stop, there's this metal on metal click / clunk sound. (maybe something loose) sounds like under rear end.
8. When i am driving at night, putting power windows up the headlights go little dim, and every 3 minutes, idling and not doing anything all lights inside car and outside car go dim for a second. continuously no matter what. it always happens every few minutes. (i'm thinking alternator maybe the cause of couple of these problems)
That's all i could think of at the moment. I think that's pretty much it .... >.> for now 0.0 these are the only things that worry me that i might be stuck at side of road one time
Thanks for any and all help
