1 - 9 of 9 Posts
Reactions: GXP25
That cradle assy is only worth about $400 to $500 with that damage. Only the diff is likely to be good. Toe rod and trailing arm bent. Hub and bearing will go bad. Axle might be ok. Text book example of a car sliding into a curb
Reactions: GXP25
Normal besides an obviously bent lateral arm. What's their asking price?
I'm not asking if this literal one. But this type and year will bolt up if I drop the one I have. You see my tire hit a tree. Now my rear end crab walks. This one is 499 though.
Indeed and didn't notice the eBay advertisement link on the phone.
Not sure if you are asking to swap the whole cradle or just the diff...
The diff will bolt up, I think the axles need to be different? could be wrong, also look up camaro diff swap, many many people have done them.
If you want to swap the whole subframe, you should search for Camaro cradle swaps on here.
Several people have done them with varying issues.
I didn't read them all but here is an example.
1 - 9 of 9 Posts
