GXPaycheck;
Looking good. The fit of the infill panels is tight to maintain the OEM fit and finish. When I installed mine a couple of years ago, I used a grinding tool to take 1 mm or 2 off the back side of the panel where the pin goes through. There is sort of a "pad" there. This minor adjustment is not always needed but taking that small amount off reduces the width enough to allow the pins to be inserted and be secured more easily.
The MAF wiring harness is tight but if you need a little extra length in the wires, you can remove the wire clip from the bracket where you would lift the engine and reroute the wires under the power steering pump. Once agin, this is not always necessary.
Several people have asked about the use of a Heat Soak Reducing Kit (HSRK). I will be the first to admit that I am not here to be the technical advisor on what different components do to your car. What I can tell is that if there was a simple modification to improve performance that could be made to any of the intakes, such as an extra hole to install a HSRK, don't you think they (the manufacturers) would do it?
For those of you considering installing a HSRK, I would ask that you consider that question and truly see if it is worth it. If it is, then I'm sure the guys at VCM Australia will be releasing a VCM 2.0 (and the other manufacturers too) in the future.
For those of you that have done the modification, it would be interesting seeing the real performance gains. Not just air temperature changes. But hey, a mod is a mod and when you have the bug, and its simple, why not.
As a way to stay on the fence with this; everyone's car is different, as is their driving habits and conditions. What may work on one car, may not work as good, or at all, on another. All I can report is that VCM Australia has sold thousands of these intakes and there is no provision for a HSRK.
Lastly, the breather tube can be tricky. However, it will fit. When installing mine, I would compare it to installing/removing a front sway bar on the G8. You have to twist it this way and that and at different angles. Be patient and it will fit in and provide an OEM fit and finish. I installed mine with the intake off to make it as easy as possible. In the rare occurrence that the tube will not quite reach or if you have an older car and tube has shrunk due to heat, splicing in a small piece of an oil based tube is the recommendation. If you use fuel line, you could run into the potential of the hose drying out over a period of time.
I hope these answers help a little. If you have any other questions, please let me know.
David
VCM USA
