yeah same oil pressure readings both via the scanner and the gauge. i wasnt able to find a manual gauge locally so i didnt test it that way.Did the same as in identical oil pressure readings? Were you able to verify the readings with a manual gauge?
new sensor did the same...
Sending unit/ sensor was replaced and presumably it is a quality unit.... buy a quality sender unit. The fact they were the same means the gauge is working well. Just save the time and buy a new sender
