1 - 4 of 4 Posts
I knew they would push my exhaust back some but they pushed the passenger side back half an inch more than the driver side. Has this happened to anyone else? How did you fix it?
Loosen the band clamps, snug up midpipe connections and then tighten the band clamps. The connection pipes have an inch or so of adjustment.
When I put the connectors on I pushed them on till the header and connector piece were butted up together. If this is what you were meaning?
Yeah, so the one that is to "short", loosen its band clamp, slide it to the midpipe, tighten band clamp. Cant say I had to do this to mine but.....
My connection pipes wouldn't fit correctly until I swapped them from one header to the other. Might give swapping them a try as well
1 - 4 of 4 Posts
