I’m trying to GE in touch with the guy that makes the paddle shifter mod kit. Josh Is his name. If anyone can plz help me I would super appreciate it. Thanks
It's been a long process but I've finally got Pat Guerra (who I totally recommend) to put a tune in right so the ECU is getting accurate speed readings and the car seems to be functioning better. I also had Chris White tune the BCM for the manual swap a while ago. Hopefully you guys might be...
not sure if you guys all know or not but aerpro in australia has made a dash kit with the heat controls built in. its way cheaper then the other versions out there. i will be installing it today. if anyone wants i will put up more pics and let you know how this goes. they have a kit for single...
Ok, as title says cigarette lighter plugs both stopped working at the same time. I have replaced the front and rear cigarette lighter fuses AND the #14 auxiliary power fuse. None of this fixed the problem and I have searched everywhere for a solution. Both stopped working at the same time...
Hey fellas,
I searched the forums and watched some videos but I could not fine exactly what I am looking for. The carrier bearing on my G8 is causing the the driveshaft to kinda wiggle around and make a clunky noise. So it needs to be replaced but it seems like it is going to cost me a lot...
