1 - 2 of 2 Posts
I am pleased to announce our newest Pedders Dealer in the USA
New Area Performance
1322 Buffalo Road
Rochester, NY. 14624
http://www.neweraperformanceparts.com
(585) 865-1832
Mike Frumusa​
Mike and his crew have been very active in the G8 community and they are a sponsor of this forum
We need a training G8 for a Pedders Track II. Here is the system:
G8 PEDDERS TRACK II WITH DROP COILS 6/10/08
The Track II combines all the components of the Street II and adds sway bars, bushes and endlinks. With the virtual pivot point design and the advanced rear suspension you tracked G8 does not need to e over sprung and over damped. In complete OE trim it will out perform many respected marques. With a Track II System we are going hunting for the big boys with big dollar stickers. We add more urethane bushes to create greater control. These are Pedders exclusively designed urethane bushes that use voids, shapes and volume of urethane to increase control while maintaining an OE like ride. There are no squeaks. It is not rough. It is AMG like control. It has long been the Pedders philosophy that sway bars are not used to correct deficiencies in your suspension. Sway Bars are the final tuning step for a properly sprung, damped and bushed vehicle. Pedders sways offer four positions of adjustment front and three positions of adjustment rear. They include Pedders HD endlinks and urethane D bushes. They are perfectly matched to provide an amazing level of control as they compliemnt every elements of your Pedderised G8.
2954 GM Zeta Front Coil Ride Height 642mm with 19" Wheels $89.62
2955 GM Zeta Rear Spring Ride Height: 624mm with 19" Wheels $89.62
5030 GM Zeta Front Strut Bearing $38.57
5851 GM Zeta Front Strut Mount Bushing $42.99
9295 GM Zeta GSR Rear Strut $178.36
429006ADJ Kit GM Zeta sway bar Heavy duty adjustable kit $649.87
9464L GM Zeta GSR Front Left Shock $230.00
9464R GM Zeta GSR Front Right Shock $230.00
EP1167 GM Zeta Differential Bush Kit $108.36
EP1169 GM Zeta Extreme Sub-Frame Connector Kit $238.99
EP2112 GM Zeta Steering - Rack & Pinion Mount $26.25
EP6560 GM Zeta Front Radius Rod Bush. INCLUDES 5421 caster lock washers $161.59
EP6561 GM Zeta Front Control Arm Bush - Inner Bush $134.98
EP7263 GM Zeta Control arm - Upper inner rear $96.20
EP7265 GM Zeta Trailing arm - Front $96.20
EP7266 GM Zeta Control Arm Rear Lower Outer $96.20
EP7267 GM Zeta Toe link - inner $96.20
11094256 ZETA REAR LOWER CONTROL ARM AND SHOCK BOLT NUT GM92138178 $33.32
G8 PEDDERS TRACK II WITH DROP COILS PARTS TOTAL $3,043.15
Labor to Include the following
Instaling the listed components
Custom 4 wheel wheel Alignment
Total Labor $1,425.00
Total Parts and Labor Less Sales Tax $4,468.15
We will be offering a 1 time only 25% discount on this system. That will put the price at $3352, a great value! Mike's shop has one of the lowest labor rates of all Pedders dealers so the value is significant.
We use the TrackII due to the training of replacing all the bushes. We do, however, have lots of different systems that range from coils only to the Extreme Track II system. If someone wants an Extreme kit, we can do that at 25% off
We will need your G8 for 2-3 days for this training. I wil personally supervise and train the installation.
We have a number of guys inquiring, and the first to make a deposit, gets it.
I will be flying in the week of Sept 15th to train the crew and meet all of you.
We will be having a Pedders Day on Saturday, Sept 20th. On that day, we wil be offering free 28point inspections. We will show you the Pedders parts that GM racing will be using on their new Camaro, which is nearly identical to the G8. At this event, all Pedders parts that are sold will be given a 10% discount, plus all Pedders Parts installed as a direct relation to this event (deposits made) will be given a 10% off labor as well!. Not only the discounts, but all parts installed by New Era from this event will be given a LIFETIME WARRANTY on the Pedders parts to the original owner. You can race it, we do not care. We will, however, not cover parts that were damaged from impact. I think you all know where I am coming from on this.
You can see a G8 Track II install on my webshots folder at
www.webshots.com/user/dmsdesign
Ask us how to eliminate apprx 75% of your body role. Ask me to show you and tell you what will be different on the new 2010 Camaro Zeta platform. Ask me which one will handle better and why
I have a lot of experience on the G8 and can help answer suspension questions that you might have. I also am looking forward seeing all of your rides.
If you have any questions, please ask
Mike
dms
Discussion Starter · #2 ·
I regret to announce that due to scheduling issues, we are going to have to post pone this event. Stay tune and watch for announcememts for the reschedule
thanks to all
mike
dms
1 - 2 of 2 Posts
