1 - 10 of 10 Posts
Basic photoshoot, just trying to compare the difference in height after the H&R lowering springs installed.
Also installed Monroe Strut Kit, which I advise you do, had a broken Bearing assembly on the stock kit. install took about 3 hours, with the addition of changing the front brake pads and rotors.
A lot less body roll than stock, handles a lot better. Stiffer but its a nice stiffness, like a sports suspension should be. As for height, I think i still want lower, doesn't seem as flush as i want it. its ok for now but most likely will be doing coilovers in the near future.
BEFORE
AFTER
iPhone Pics
Dirty car
AFTER (SLR)
I think it looks perfect! Nice pics!
What are the details on your wheels, please? Drop definitely helps. I was thinking I was going to retrain the OEM suspension setup on my GXP for as long as possible but a slight drop definitely looks better, especially with aftermarket wheels pushed to the fenders!
Wheels are ESM model 004 (BBS LM reps)
They are
19x8.5 35mm front
19x9.5 40mm rear
Tires
Front are stock 255/40
The rears are 275/35 hankook v12
Still need to get the front tires in Hankooks, probably 255 or 245/35
Did you take any before and after measurements to see what drop you actually achieved? Can you post that info? I swear the hardest choice for me is which springs to get. Your ride height looks good, but I'm worried about wheel rub with the H&R's since I'm on 20's.
I told myself I was going to and completely forgot to do so. I'll take a look at it later and try to get a close estimate. They are pretty settled now and still have some clearance, depending on your offset I think you could fit them. I had my rear fenders rolled.
Yeah it seems like most forget to take before measurements. If you have a chance to get some after measurements that would be cool.
They are
19x8.5 35mm front
19x9.5 40mm rear
Tires
Excellent, I'm thinking 19x9.5's all around with +32 offset (the only option available in the wheel I want with our lug pattern unfortunately). Those should be fine, right? For tires, probably 265/35 square...
1 - 10 of 10 Posts
About this Discussion
6 Participants
Devilthe0ry
Full Forum Listing
