Okay guys, I've done as much research on here as I can and haven't found any cases quite like mine. Here's what I'm up against:
I got the big red X and "Contact Dealer." Of course, it didn't set off a CEL or any trouble codes. It was scanned while active with my OBDII, and with a TechII at the dealer. Found nothing.
The X is still up and has been there for over a week now. The car drives great, and everything functions as intended. However, the odometer is frozen at 63,541. The trip odometer is frozen too. That also means my estimated MPG is now stuck at 0. My fuel range eventually drops to 0, but when I fill up it still shoots up to as high at 100-something.
I've disconnected the battery, checked every single fuse (under the hood, by the battery, and in the driver's footwell). I've double-checked as many grounds and connections as I could visibly/easily locate under the hood.
:dunno: My only idea is either something in the cluster has actually failed, or somehow the battery is effecting it. I do still have the original battery in there.
Anybody have any ideas? Thanks in advance for any/all suggestions!
