Not sure if anyone has seen or experienced this issue, but for the third time now I gotten a mass number of DTC codes (below) that put the car in limp mode.
U0121 ABS
U0101 CM and the EBCM is not working?
P0700 The PCM detected a malfunction in the transmission control system
P2544 Input signal malfunction (TCM and PCM)
P0856 Traction Ctrl
P0073 Power Control Module (PCM)
I may try and look at the TCM and its connector, I do not think the ECU has failed because the car still starts and runs fine but triggers a mass number of DTC codes...
I pulled out all of the fuses and reseated them, cleared the DTC codes then they came back after driving about 10 miles down the road or so its a weird intermittent problem.
Any help or suggestions is appreciated.
I have 62k on the car.
Thanks,
Gary
U0121 ABS
P0856 Traction Ctrl
Thanks,
Gary
