1 - 20 of 28 Posts
Supporting Vendors
Pontiac G8 License Plate LEDs! Plug & Play Install! Same day Shipping! Upgrade Today!
License plate bulbs are used to illuminate the rear license plate on your G8. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your G8!
The installation is 100% plug-and-play, just replace your factory bulb.
With low price and easy install, this is one of the best, easiest modifications you can do to improve how your G8 looks at night.
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
Brightness:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your G8).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
2008-2009 Pontiac G8 License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Are you guys gonna do anything with OLED technology? Praying for after market tail lights like what the audi swarm does.
Supporting Vendors
Discussion Starter · #4 ·
We are always implementing the newest technologies into our products, but OLED is still a few years away from aftermarket applications IMO.
Nick C.
I haven't had good luck with these LEDs. I think it was the HP3s that I ordered a few sets of for my G8 and the wife's minivan around Thanksgiving '15. They lasted a couple months in the G8 before flickering. I got a few warranty replacements that started flickering as well. I replaced them with Sylvania LEDs that are doing well. The set in the van had been fine until this last Christmas and they both started flickering at the same time. I got a cheap pack of 10 off ebay that so far are working fine, but we'll see.
I've got other DD bulbs like switchbacks for the front and I think some backup bulbs and I really like those!
Supporting Vendors
Discussion Starter · #6 ·
I'm terribly sorry to hear about your luck with the HP3's. I'd be happy to replace them with an upgraded set of HP5's!
Shoot me a PM!
Nick C.
Supporting Vendors
Discussion Starter · #16 ·
There's no better time to upgrade! Through Friday, 5/29/2020, get 20% off all our LED upgrades for your ride, including our License Plate LED Bulbs with coupon code "USA20" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Friday, 5/29/2020. Cannot be combined with other coupon codes.​
Supporting Vendors
Discussion Starter · #17 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 5/29/2020, you can use coupon code "USA20" at checkout for 20% off your entire order of lighting upgrades, including our License Plate Bulbs!!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Supporting Vendors
Discussion Starter · #18 ·
Don't miss your chance to save on all LED upgrades! Through Monday, 7/6/20, get 15% off all our LED upgrades for your ride, including our License Plate LED Bulbs with coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.​
Supporting Vendors
Discussion Starter · #19 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/8/2020, you can use coupon code "LABOR" at checkout for 15% off your entire order of lighting upgrades, including our License Plate Bulbs!!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
1 - 20 of 28 Posts
