1 - 4 of 4 Posts
my Pontiac G8 has these on (Reduced power and Safety mode) and now it won’t turn on anyone knows what it can be? I already disconnected my battery to try to reset my sensor...
2009 G8 GT
You'll have to hook up a scanner to it to get the codes, it can be so many different things.
What Hot Rod said. You need a lot more information, and in order to help you so do we. If you don’t have a scanner/code reader, most auto parts stores will scan the codes for you.
That error message usually comes up when there's an issue with the throttle body. Whether the connector is disconnected or the throttle body isn't working properly.
It can also be associated with the crankshaft position sensor and the accelerator pedal position sensor.
1 - 4 of 4 Posts
