I've read quite a few threads on this topic, hopefully this thread can answer questions about the install and parts needed.
Once again, a HUGE thanks to RealSquash(Andy) for his help on the install. Always a very trusted resource.
Initial Review: I'd say I probably picked up close to 4-5rwhp. The car runs very smooth through the powerband, isn't as choppy. Might rev a tad faster, can't really tell. Overall it is great install to do when you do a cam install as well. My pulley wobbled very bad after the cam install so that was my main reason behind installing the new pulley, not for HP gains, but those are always beneficial. AC runs great, alternator runs great, no issues there. Below is a before/after of the pulley wobble.
Before:
After:
Parts
Pulley: I purchased the pulley from [email protected] Era. The price was fantastic($179), shipping was even better. Mike went above and beyond to make sure that I would receive the pulley by Friday. I ordered on Sunday night, it was on my doorstep Friday @ noon for my Saturday install. Thanks again!
Part # PBU117-SS25
Belts: You need two belts, AC and Serpentine. Part numbers below:
Serpentine: Dayco 5060745, DO NOT USE 5060750 - Too Big!
AC: Dayco 5040410
I purchased these at Advance Auto, I think the Serpentine was $24 and AC was $14. They were in stock. If you have a supercharger, I would recommend you go with a Goodyear Gatorback belt.
If you are having doubts on which belts to get, you can reference this guide: http://www.tufautoparts.com/files/TUF_Serpentine-Belts_01-22-2008.htm
Bolt: I purchased a new GM TTY OEM Crank Bolt, was $5 at the local stealership. Part # 12557840.
Install
Remove Radiator Fans(these bottom clips are stubborn):
Get out the 600ft/lb impact and remove the old bolt:
Put on your pulley puller and begin to remove the pulley:
Admire your new pulley:
Before:
After:
Parts
Part # PBU117-SS25
AC: Dayco 5040410
Install
