1 - 18 of 18 Posts
well i got a friend of mine that installed a tvs1900 supercharger along with the magnavolt, injectors, kooks headers w/ full cat back exhaust, a/f wideband gauge, boost gauge, and fuel pressure gauge with the jhp gauge pod, and the shop that is doing the install ran into a slight problem... so it so happens that the car starts and turns on fine, radio and windows and other electronics work fine aswell, the only problem is that the speedo, rpm gauge, fuel level gauge, and temp. gauge dont turn on at all but the check engine light is on. we cant find the problem and well my friend already posted it in another section but i thought this section would be more appropriate, the shop thats installing everything has looked for anything possible that could be cause this but we cant seem to find the problem, i would like information or anything you think could be causing the problem that way i can run it to the shop owner so they can check it out, btw has anyone else had this problem???
Where did they tap into the wiring for all of the electronics? Did they check all fuses? Did they check for loosely grounded ground wires? You install a lot of stuff all at once, it could be any number of things possibly causing that unless someone else here has seen that same issue...
Red Sox Nation !!!
Like what, what have you checked? PCM? BCM? Fuses? Cut wires from the gauge installs? How are all the gauges powered? Did you take the dash out?
Way to may things to have gone wrong.
Do you get the DIC on?
Have you done a self test in Maintenance mode? With the car off hold in the left steering wheel button and then start the car at the same time. The self test is the last thing on the list.
well they've checked all the fuses and all grounded wires and everything is working fine and grounded fine, ill tell them to double check it tomorrow and see if maybe they over looked something, they have already taken the cluster out to make sure everything is connected right and nothing is loose or not connected and everything is in place where it should be. what is the DIC?
Red Sox Nation !!!
The DIC is the driver's information center, it is the red screen between the tach and speedo. Is that on?
sorry for the newbie questions, and well i just spoke to the owner/mechanic of the shop and he said that the DIC does not turn on at all, the only thing that turns on on the instrument pannel is the check engine light.
This is one of the pitfalls of installing too many things at once...
Red Sox Nation !!!
Try and see if the maintenance mode will work, even though nothing is on. The cluster is getting power if the CEL is on.
Contact member GTPprix, he seems to know his stuff when it comes to G8 electronics.
what is the maintenance mode and how do i check if it works? let me send him a pm and see what he recommends to check.
first suggestion - find another speed shop that knows what they're doing and/or has done a similar build before on a G8 or similar GM vehicle - have them dive iinto it. If that isn't possible you may have to seek out a dealer.
well actually these guys have installed numerous tvs chargers on camaros and on a silverado with 408 stroker and thats why we took it to them.
worst case they might have to start removing things one at a time to determine what is causing the issue if all fuses and wiring has been double and trippled checked...
Isn't the CEL feed a dedicated line into the IPC? It seems to me on most newer vehicles the CEL is independent of the rest of the data that the IPC uses to display data, which would explain why the IPC might be dead, but CEL would still come on.
Besides, if the CEL is on, check the code. I bet you'll find a U1000 code between the IPC and the ECM. If that's the case, I would assume a data line has been cut/broken/tampered with.
I don't see G8's in that list.
And most definately our wiring harness and dash board are unique to holden VE / pontiac g8.
Did they check both fuseblock panels (driver kickpanel AND under the hood) for any blown or non-functional relays, fuses, or fusable links? It could be something as easy as that.
What I don't understand is why aren't THEY (the speed shop that broke the car)... aren't escalating it, since it's obvious the shop F'ed up and messed up the car? If it were me, I'd be demanding that they either fix it, or tow it to a dealership who has a tech2 and who knows how to work on g8's to fix it. Of course then, the speed shop would most definately pay the entire bill to the dealership for it to get diagnosed and fixed (properly this time) ... and hopefully be all the more wiser for their next g8 project not to do the same thing that killed your ICS.
Strikes me as funny why "you" and "he" are doing the legwork that any experienced speed shop worth their salt should have been able to fix or at least call around and utilize their resources to figure out.
Do they even have G8-specific service manuals? That's a good place to start the troubleshooting. My bet is that they don't.
See if you can locate the g8 service manuals and let the speed shop tear into them. Maybe that'll provide the training that they need to properly work on g8's. :(
Northeast G8 Owners Club
Not sure if this will help but disconnect the battery and see what happens! It's a long shot but just might help to reset something!
If not i would take it straight to the dealership and have them look at it. The speed shop should cover the bill!
This is one reason i try to do most mods myself and if i can't do it myself i print out as much info as possible just in case! Well i hope your friend get's it fixed and that one or our suggestions works.
Yeah I would be a little upset myself if a speed shop were in such a quandry and didn't seem to have the forsight to seek out professional assistance...I sure hope they didn't "fry" anything electronically that isn't easily repaired...
Red Sox Nation !!!
Shops love to tap into existing wires instead of using new wires and new fuses. If they tapped into the wrong line, then they would be screwed.
The G8 runs on a CAN BUS system which is really different than any Chevy. From what I understand.
1 - 18 of 18 Posts
