Like the subject says, my upper radiator hose popped off due to the plastic radiator lip breaking off that so many people have experienced. This happened on my way home, only about a mile away. The car started to overheat and I made it home just as the car put itself into safety mode and switched to low power. I have a new radiator on order (Cold Case all aluminum). I got the hose temporarily reconnected using two clamps. But now the DIC is saying that I need to service the engine oil. When I go into Engineering Mode the oil life says 0%. Is this a problem? Will it fix itself or do I need to change the oil, or hopefully not, the oil sensor?
Oh, I also changed the thermostat before I saw the top hose was disconnected.
