1 - 15 of 15 Posts
I'm at the inlaws for Christmas and I got a Bluetooth obd2 reader. The car freaked out when I plugged it in and dic displayed see dealer. I managed to read and erase codes with it, but I still have a check engine light.
If I was home I would just check it with my $20 actron scanner.
I searched and couldn't find how to read the cel on the dic. I know you can because I have read on the board before that you can. Would someone please learn me!
Discussion Starter #2
Finally found it. Hold drivers menu button (one with road) while turning key to on position. But mine says no codes and as soon as you start the car the cel comes on. Sigh, guess I'll be driving home with a cel :(
Never having a check engine light(mil) displayed, I can't help you there. In fact, I didn't know it was possible to actually see any codes when in engineering mode. But if the code you had seen displayed was of the type I'm guessing, it would take 3 or 4 engine start/run cycles to clear itself, an only if the problem that created it, is no longer being sensed. It of course would cancel right away if a code reader/scanner has that ability. Maybe that device you have can not due that. That device (you talk about), is a little over my head.
If in engineering mode, my take on it is, if you hit the DIC display rocker switch ( the one you talk about), it reverts to DIC info an cancels the engineering mode readouts. If you were in the engineering mode with key on only (static looking), after key is turned to off an then back on, it will have automatically defaulted back to normal DIC display.
Not exactly, to see CEL codes you press the road button while turning on the car, not the scroll wheel.
If you got onstar you could call them to see if they can read what code it is. You could always stop at a autoparts store, most will read the codes for you.
colby1035--- How bout that, I hit the *road * button an you are correct. It displayed *service reset + no items* Pressing the scroll wheel, or turning off ignition then turning back on again, reverts back to normal DIC display. Nice little item there. Hope I never have to go into that mode, other than to see that its still functional.
Lol Onstar. I can do anything they can for free.
The CEL was gone the next day when I drove home.
You can unlock your doors remotely without the key fob?
Do tell!
If you are referring to the need to unlock the doors because I can't find the key or I locked them in the car, my $25 hide a key saves me hundreds in Onstar fees a year.
Exactly where did you stash the hide a key? And could you please PM me the address where your car will be parked? Thanks in advance. :gr_jest:
.........ya, because I've heard lots of stories of people getting there car stolen because of a hide a key.
The 'codes from the DIC' theory ;) is a very common misconception...guess I'll hop in w/some clarification (only to read the same thread about DIC 'codes' in a week lol)...
The 'codes' displayed in the DIC are NOT P-codes (P-Codes are the fault codes that set in the the Engine controller associated w/CELs)...
The 'codes' displayed in the DIC are a completely separate thing, not even sure what they are for (maybe to confuse ppl lol) but from memory they are either BCM or Cluster codes - not in ANY way related to CELs!!
So please stop trying to find out why your CEL is on by playing around w/your DICs ;)
So there - spread some truth, kill the DIC code rumors ! :)
I always keep a spare key in the bottom of the fuel tank. When I need it, I just simply remove the fuel tank then pull out the fuel pump and reach a long magnet down into the bottom of the tank to retrieve the key, it works great :)
Discussion Starter #15
Hey guess what I'll be doing with the extra few hundred dollars this year I saved by not having a Onstar subscription.
Whatever I want, because I'm not an ignorant dumb ass.
1 - 15 of 15 Posts
About this Discussion
7 Participants
ovrebo1
Full Forum Listing
