I am in the process of performing this swap now. I just ordered the last pieces, the Camaro rear upper Control arms. One thing to keep in mind is that the Camaro assembly uses a different spline outer cv joint, which means that you will need to use either G force axles or possibly the Camaro SS axles. I do not race the car, so I am trying the Camaro axles myself.
Since The Camaro SS axles are .4" longer, I will need to test for binding when I do the change. I spoke to Andy at Squash, and he says that he has already performed this conversion, with both axles. He stated that if the car is stock height or slightly lowered, the Camaro axles will work. Although I do not know what slightly lowered refers to yet... I will update the post once I complete the change over.
