1 - 20 of 21 Posts
2009 Pontiac G8 GT
Very happy with these smoked LED diffuser reflectors. :cool:
184958
2009 Pontiac G8 GT
Seen the led deflectors but don't recall if they were smoked or not. If I remember correctly, the member incorporated them into the rear turn signal as well.
Reactions: BAS G8
I have them too. Just have to decide if I want them to go with the brake lights or running lights.
184959
Reactions: FiveOWithA6.0
2009 Pontiac G8 GT
Discussion Starter · #7 ·
My neighbor helped me out and wired them up with the running lights. They are a solid red, the don't get any brighter when you hit the brakes. I like them that way they look sharp.
2009 Pontiac G8 GT
Discussion Starter · #10 ·
I have them on my car and they do get brighter when the brakes are applied.
Hummmm... do you happen to remember where you wired them in? I'm beginning to think mine might be wrong lol. Did yours only have 2 wires coming off the reflectors?
2 wires. The black goes to the ground and the green goes to the brake light. When the lights are on they are lit. When the brakes are applied they get much brighter. Easy and cool mod.
2009 Pontiac G8 GT
Discussion Starter · #12 ·
Thanks! I need to double check where he wired the green.
2009 G8 GT
If you look behind the tires up in there you will see the trunk vents, perfect spot to run the wires up to the trunk.
2009 Pontiac G8 GT
Discussion Starter · #17 ·
This^^ No drilling at all. Was actually a really simple install.
2009 G8 GT
Right here.
2009 MGM GT. In need of wider tires and LSA
I hated this when i did mine.
Green is universal ground in my mind
Ground* wire typically has black sheathing and seems to be standard on most vehicles. On the other hand, black is the color of the "hot" wire from the electric panel in both residential and commercial applications.
1 - 20 of 21 Posts
