1 - 6 of 6 Posts
To me this means returning the TCM & PCM back to stock.
However, with the Cortex, when you select stock it loads the Superchips PCM settings.
When you have any tune other than stock you can set your PCM settings to STOCK. But load the stock file & it loads the PCM with SUPERCHIPS settings.
To me this is a bug & should be addressed.
Comments, work-arounds?
Its Good To Be Tha King
No problems with mine, and have had it for around 3 years now.
Call Superchips if you have any problems Tech Support. P: 407-585-7000. P: 888 227 2447
After loading the stock file go check settings. Then look through all of the trans settings.
They are not stock.
I've never tried to look at the stock settings, but rest assured, if you flash back to stock tune, it's the stock tune. The tuner may retain info, such as your vin and other info.
Shannon
So i have not been on here in awhile, did we ever get the firm numbers for the best CAI and the superchips tune? Last i heard the Rotofab was hands down the best one. Is that still the case?
Why would that change? :)
Rotofab FTW!
1 - 6 of 6 Posts
