1 - 5 of 5 Posts
My ac compressor works fine. But I've chucked the AC belt enough times that I've broken bits of my pulley off of the compressor. It is possible to just replace the pulley on the compressor without replacing the entire unit?
Yes. Once regarded impossible, I have seen posts here or other board with pulley PN. Someone put much work into mining the PN. I suggest using Google as the search engine when looking in the forum.
Since that is not a traditional clutch type pulley that wears out you could get it off a used vehicle. If those are in any better shape. But not seeing it as a separate part in the catalogs.
My compressor is bad but my pulley is good.
I ended up replacing the entire compressor years ago but I still have the old compressor. Make me an offer.
1 - 5 of 5 Posts
