I had an Eibach lowering crack on me so I am replacing the set with new ones. The question is, when I installed them about 50k miles ago along with the FE3 GXP shocks/struts I also replaced factory strut mount with the BMR poly units. Question is, if I am going to replace the springs now, is there anything else I should or will likely need to replace when doing the spring swap. I don't want the local shop to get started and then get a phone call that they need something that is not readily available and car gets stuck at the shop for 3 days. Any advice would be greatly appreciated.
