1 - 4 of 4 Posts
A few months ago I purchased a 2009 G8 GT, I plan to do some mild performance modifications, but mostly I want this car to look good.
Ive been looking at rims for a about 4 months, and finally settled on a set, it was love at first sight. I'm open to exploring other options, but it's going to be tough to change my mind.
Gary H posted pictures of his new set up a few weeks ago, and thats what really did it for me.
http://www.g8board.com/forums/showthread.php?t=73233
He states they are 20x8 up front an 20X10 in the back, I'd be ok with 20X8 all the way around, but as you can see, the rears have a totally different look.
The ONLY way I can find these rims is at a 35mm offset, from my research, I hear this wont work, but he obviously did, AND he is lowered.
I am pretty educated on tire sizing and how they fit rims, but offset has always confused me. I hear that 45 or 50 mm will fit, but I don't know where the issue lies, is that a 35mm will have the tire sitting further out, or further in?
If its sits too wide, then fender rolling and a narrower tire should help/fix. if it sits too narrow and rubs on the inside, then a spacer should help. I have two 6.5mm spacers that I used on my SS and had zero issues.
I've contemplated lowering, depends on how it looks with the 20s, if I did, Id either do the Eibachs since the drop is minimal, or the coilovers so I can control it.
I very rarely have anyone in the back set, and never carry more weight than groceries...my car is borderline garage queen.
Here are the rims in question.
[ame]http://www.amazon.com/KMC-Rockstar-Wheels-5x114-3-KM77521017735/dp/B007OX7O0A/ref=sr_1_18?s=automotive&ie=UTF8&qid=1370730199&sr=1-18&keywords=kmc+rockstar[/ame]
[ame]http://www.amazon.com/KMC-Rockstar-Wheels-5x114-3-KM77528017732/dp/B007OX7P4U/ref=sr_1_6?s=automotive&ie=UTF8&qid=1370730199&sr=1-6&keywords=kmc+rockstar[/ame]
Discussion Starter · #2 ·
BTW, my car is SRM, I think with blacked out chrome, and these rims...it would be beyond sexy, I'd also do what Gary H did and fore go the center caps and paint the chrome studs.
http://i104.photobucket.com/albums/m170/Rican219/2008 G8/IMG_0858.jpg
According to google images, this guy has done it, it sourced the picture to these boards, is Rican 219 a member? It also showed some commodores with this set up.
Discussion Starter · #4 ·
its pictures like that, that confuse me, but I think I have it figured out now, the issue with a low offset, is that the rim sticks out too far, and rubs the fender. A spacer would only make it worse.
I found some other pictures of these rims, it looks like the hub is really thick, I wonder how difficult it would be to get a few mm milled off the inside. pull that offset back to a 40 or 42.
I found the thread that the picture came from in my second post, he's running a 275 on the rear, rolled, lowered on Eibachs, without much trouble.
1 - 4 of 4 Posts
