1 - 6 of 6 Posts
two lane black top
idk if anyone here is lookin for material info on rims but after oing research i found this on the website. its really intuitive. enjoy.
Originally Posted by Red Racer
As far as pros and cons of wheels go, wheels are wheels. If they are heavier than stock, rebound will suffer, if they are lighter, rebound will improve, which improves traction and stability over bumpy and uneven surfaces at speed. The offset is of some importance also. If they increase trackwidth, even just a little, the suspension settings will feel softer, due to the added leverage against the suspension components and visa-versa for less offset.
No offense, but "wheels aren't just wheels". They are one of the most complex and most under regulated and inspected componets on a car. There are countless threads on tires and oil on every forum, but most look at wheels as fashion accessories.
Here in the US, the industry regulation is a joke and most of what you see on the road is imported from China and made from recycled aluminum or a price point driven alloy, not a performance driven design. Also, there are very few brands who produce their own, and even those that do often don't use the best methods, materials, engineering or finishing processes. Here are some things to keep in mind when choosing a brand. I'll refrain from offering my personal opinions (or inside company knowledge) on specific brands, so if you want details on something specific, feel free to PM me direct.
Materials:
Aluminum is lightweight but tends to bend easily, so you mix in alloys to add strength. Only 1 brand mixes their own, most buy on the commodities market what's available and what's cheaper at the time.
Magnessium is lighter but very prone to hairline cracks. It's corrodes easily with atmosphere and UV light so wheels need to be constantly checked for chipped paint and touched up. It's usually 2x's + the price of aluminum so it's rarely seen in street wheels (Porsche Carrera GT uses a forged magnessium wheel that is $7k cost per wheel).
Carbon: used extensively in street bikes, just recently offered for street cars by Dymag (Koenigsegg is first production car to use), sometimes uses an alloy spoke, sometimes a carbon/kevlar weave. 1/2+ the weight of aluminum and magnessium and better impact properties. As use increases and production costs go down, it will be the best option for most performance applications.
Types:
1 piece: entire wheel is formed from 1 piece, meaning offset is fixed. Usually cast.
2 piece: outer barrel with a seperate inner face. Offset is usually set (sometimes adjustable by using different spokes shapes), allows you to swap out spoke designs or mounting patterns.
3 piece: barrel is made up of an inner, outer, and by mixing and matching, you can create custom offsets easily and them mount a center section for different spoke patterns and mounting patterns.
Process:
Cast: weakest and most inexpensive method. More porous product so you need a heavier and thicker design to make product strong. Typically seen on factory cars. Usually a 1 piece design, can be elaborate since it's a casting, occassionally it makes it way into a multipiece design.
Flow formed cast: large steel rollers press and stretch the outer rim of a heated cast wheel to compress material and give properties similar to forged product. Also uses only 4" of material to make a 6" wide wheel (less rotating mass)
Die Forged: Multiple pressings control the grain structure to allign down the spoke, curve with the bend and follow the radius of the outer barrel. Most expensive of processes however the strongest, lightest and most consistent as all pieces are forged into product.
Rotary Forged: The material is rotated under pressure and this forces the material out into a disc. The structure of the material is not as uniform as die-forging, entire product has a circular grain structure (weak spokes). Although this is considered a forging process, it does not use the extreme amount of pressure that is used in die-forging
Solid Forged: The initial forging is produced from a single tool. The rim is spun and then it is ready to have the design machined into the solid center. They can produce many different designs and bolt circles from a single tool.
Semi-Solid Forged: Combination of casting and solid forging process
Things to consider:
-US DOT stamp is a joke.
-German TUV should be minimum requirement for your consideration
-Japanese JUL is a little more strict, but it's a small market so not all brands submit for certification
-Some brands "build to your specs", that means alot of stacked tollerances which can lead to a wheel that isn't necessarily round, or one where the center bolts aren't properly centered.
-Load ratings are important. yes, a wheel may bolt up to your car and clear brakes, but if the load rating isn't accurate, you could have a major failure
-Magnessium wheel age. A deal on a set of race wheels is rarely a good deal
-Air corrodes. A quality wheel will have the inner barrel (inside the tire) painted and sealed to prevent this.
-When possible, use Nitrogen in tires (more stable, holds consistent pressure longer, removes moisture from air and less corrosion)
-Wheels can rarely be repaired. The heating and stretching process changes the grain structure. You're effecting roundness, weight (balance) and strength of the wheel
-DON'T POWDERCOAT!!! Powdercoating heat cycles a wheel, and usually need 2-3 attempts to get consistent finish. Each thorough heatcycle (track use and brake temp flashes don't heat through) can reduce the structural integrity by as much as 30% each time
Trust OEM. If someone isn't using it as OEM on their car, I'd be very hesistant to trust it. Yes, OEM designs are a compromise in performance and cost, however OEM's are scared of lawsuites and insist in quality and capable products. If no one is trusting a brand for OE use, I wouldn't use one of their aftermarket products.
Since you asked about 2 specific brands.
OZ is currently controlled mostly by Tirerack, if buying a product for your car, be sure to research exactly where it was made as all items aren't still made in Italy as they once were. Overall a quality and consistent product. Used by OEM in some applications as well as spec for some racing.
Enkei is usually used in cheaper Japanese applications but have recenlty seen a few high end cars using it. Some Japanese OEM applications, consistent and quality product, I'd check load ratings on specific model before using on the track or for heavy driving.
Hope this helps
i do not take credit for any info on this post this info
http://www.ferrarilife.com/forums/supercars-288-f40-f50/7984-f40-aftermarket-wheels-oz.html
Super Moderator
Sub'd to remind me to read all this later. haha
two lane black top
lol reminded
every village has one
I'm going to have to go out and check my stored 18 inch GT wheels, but I think they are made by Enkei.
two lane black top
to my understanding the stock g8 gt rims are enkies
GM uses Enkei as an OEM for many of their wheels.
1 - 6 of 6 Posts
