1 - 20 of 27 Posts
Hi guys, just picked up a 08 G8 V6. Liquid red with GT trim. Ive only filled her up twice with Exxon 89 octane fuel. I start her up immediately after filling up and both times she had a rough time starting. Just wondering if anyone else has had the same issue.
Ins-Z-G8-toR
Maybe injector issues, or spark plugs..
Don't over fill it. There is some vacuum system with valves and sensors that gets messed up if you overfill. I forget how it affects the engine control system.
I just got done putting more gas about 30min ago. I only put 20 bucks in (3/4 tank) and it did the same thing. Should I just try changing the spark plugs first?
OGOC Member
Could be several things hard to know fow sure from here. I'm thinking maybe leaky injector or bad plug. Maybe bad gas cap. As u say only when u put gas in it.
Check for codes even though no dash lights are displayed. But changing plugs is a cheap thing to do and would eliminate a chief suspect. Also you can pull the plastic cover off the engine and start the car in the dark and look for arcing from any cracks in the plug wires.
OGOC Member
No plug wires in the V6. But yes check for codes if any.
Ins-Z-G8-toR
I see the issue now...v6... lol
awe...C'mon man...^^ what whatnext was saying seems legit, im still stuck on the only when you fill up thing. I would definitely pull the plugs and see if they look fuel fouled, possibly a bad fill valve allowing gas to go into the charcoal canister? esentially flooding it when you start it? lots of possibilities.
I have not witnessed this issue in the g8. But Im a Hyundai tech of 15 yrs and this occurs when you fill up the tank. Caused by a stuck open purge valve that sucks up extra fuel or vapor and basically what acts like a vacuum leak. This will make it hard to start and run rough for a few minutes and rarely ever throws a code. Have to remove and see if you can blow through it. Its a normally closed valve. (purge valve)
^^^^^ I think that same condition can (and I believe has) happened with the G8 in the past. Every time the ECM requests the purge valve to either open or close, and the valve responds with a proper signal back to it, then you would not log in a fault code an turn on the check engine icon. But if the valve actually failed to close properly, I agree that fuel vapors will start loading up in the intake during fueling. In my mind, that would make for a stumbling start an run condition, until the engine had purged all of that extra fuel/vapor out of the system.
Added thought >>>>> In the meantime if you want to try this at your next fuel fill up, try the *Clear Flood Mode* procedure to see if the engine will fire up and idle correctly, on it's first post fill up. Step on the pedal to the WOT position (an leave it there). Then move the ignition to the start position and allow the engine to crank for a few seconds. This action causes the ECM to shut down the fuel injectors (for as long as the WOT position is maintained). This action would allow the engine to purge itself of any excess fuel vapors that might have entered the cylinders. BUT be prepaired to release the throttle, just in case the engine try's to light off (even thou the service manual says it won't).
Discussion Starter #13
I'll give that a try next fill up. If it purists I'll change the plugs and go from there. Thanx for the info guys. I'll keep you posted.
08G8V686 it's been almost one year since you had the issue at start-up right after fueling. Can you please update on what was the problem? I have the exact same issue with my '09 V6 G8. I suspect it is the purge valve. Thanks!
Years ago I had same issue after filling up and topping off;car would have an extended cranking before starting,it was the purge valve that was faulty,I replace the purge valve.So now when I fill up and the gas nozzle kicks off I don't top off.problem solved never again had the issue
^^^^^ On the V6, they show in mounted (in a horizontal plane) on the drivers side. It looks to be right near (or between) the #4 an 6 plug area.
OGOC Member
Yes you are right. Its held on with a 10 mm bolt. Its attached to the upper intake manifold.
When you shut of your V6 do you hear a "humming/whining???" sound for 3-5 seconds followed by 2-3 clicks under the hood.
My purge valve went last year and with the new one installed this sound became more pronounced as it it apparently the purge valve doing its job.
In a nut shell if this is not happening under your hood it most likely is the purge valve.
Hope this rather vague sound/click thing helps but its the best I can explain.
Hah, always thought that sound was coming from the throttle position sensor on the throttle body. The part number for the vapor canister purge valve/solenoid is etched directly on the front.
1 - 20 of 27 Posts
