1 - 3 of 3 Posts
My key is stuck in the ignition and security lockout active. I have no power! I have changed the battery still nothing. only fuseable link I see is the one back by the battery on the positive post. is there another useable link somewhere that my have blown?
Get a meter an verify if you have battery power from the underhood jump post to the jump ground stud. If OK, then verify if that battery power made it over to to the underhood fuse box power stud. No power at that location, would wipe out the power to the car (an trap your key in the ignition switch). If there is no power at that location, it would indicate that the big power wire that goes from the jump post, to the Alternator, an then to the fuse box is damaged somewhere. A 175 fuse link is wired into that big wire that goes from the jump post to the Alternator. If it blows, you have no power to work with. If you have headers, maybe they have come in contact with that wire run, an burned it up enough to cause the problem.
I have already check that earlier and there is power at every location. I can’t seem to find the 175amp fuse by the alternator I just see a wire that goes up to the the positive stud. Only fuseable link I see is the one back by the battery. Do you have a photo of the 175 fuse on your car so I can see if I have one at that location
1 - 3 of 3 Posts
