1 - 1 of 1 Posts
I have seen a few posts related to this but wanted some specifics if anyone has had the same problem. In the shift assemble there is a micro switch which releases the key from the ignition. There is a pin which is in place to push the switch. However, my pin will slide toward the passenger side and will not engage the switch, thus locking key in ignition in the on position. Has happened twice now. From what I can find, it looks as if it is a part for the shifter base and probably not sold separately. Anyone else had this problem and a possible solution?
1 - 1 of 1 Posts
