1 - 2 of 2 Posts
Went to turn my car off and key would not go into off position. What I've attempted...
Checked fuse number 16.
Side view mirrors work so not the relay.
Tried to put it into park firmly just to try and get the key out.
Had to pull the dash panels and pull the pin manually on the solenoid and take the key out.
When the car is on or off you can shift into gear without stepping on the brake.
Shifts into gear with no problem.
Everything I'm reading is pointing to the shift lock actuator solenoid?
Any insight would be greatly appreciated.
1 - 2 of 2 Posts
