So after having my front end damaged by a deer and GM redesigning the radiator support, my RotoFab radiator cover no longer fit. SEE ORIGINAL THREAD HERE. I was randomly searching Improved Racing's website and saw that their support brackets for the VCM intake looked as if they might work for helping to reattach the RotoFab radiator cover. After calling them and speaking with them and initially having them send me the wrong parts we decided that they would send me all the support brackets that they make for the VE and VF model intakes and I could see what (if anything) would work and whatever I didn't use I could send back for a refund. Well, I finally got around to trying to fit everything and this is the solution I came up with.
The brackets with the red rectangles around them are the ones you need. These are part of their VF intake kit. The top ones are to support the outer two mounting locations for the actual air filter housing on the VCM intake. The ones in the lower red rectangle are for the side infill panels that they sell. I ended up only using the one on the right side, but they don't sell them individually so you'll have to get both.
I ended up cutting the side fill panel support bracket in half roughly and mounted it near the fuse box on the passengers side. I had to cut it to be able to rotate it enough that it would line up with the hole near the fuse box on the RotoFab radiator cover.
Next you'll need to mount the two brackets in the top red rectangle in the first picture. I have highlighted how these mount in purple rectangles on the installation instruction from Improved Racing's website.
Now these don't have anywhere to bolt to like in the install instructions (because the install instructions are for a VF). So what I did was line up the bracket on the mounting location and drill a hole where I placed a bolt and nut to hold it roughly in place.
This shows how the bracket mounts:
I then traced around the front edge of the bracket to show me where I needed to drill a hole to be able to place a bolt to hold the bracket in place. Without a bolt (or something else there) the bracket would just slide off the plastic. I drilled a small hole right in the middle and towards the rear of the car so that I could put a bolt through.
I then also cut the mounting brackets roughly in half. This step isn't necessary, but the brackets seemed to fit better when trimmed down. There's some wire looms that are kind of in the way if you don't trim the brackets down.
I added some 3M double sided tape to help hold the brackets in place and line up the holes with the radiator cover.
After all of that you now are able to mount your radiator cover. The second from the driver's side is unused. I just put an extra clip in there to make it look finished. It's not a 100% perfect fit, but it's pretty close and I'm much happier with having the cover on then having it off.
Do anyone else have this issue with this plastic panel near/under the passenger side wheel?
I saw another parked G8 the other day and noticed that this panel was sagging as well.
When I was last under the car, I noticed that this panel looked like it would sag but I didn't see an extra hole...
Does anyone have or can someone take photos of their plastic cowl that is below the windshield. I had my windshield recently replaced at Safelite and now there's a gap like previously mentioned on some threads. I want to compare because the tech is telling me it's normal to have a small gap.
I have a 2009.5 black G8. I noticed that my spoiler was starting to get loose, but seemed to be on there pretty good. Driving to work Friday and after I get to to work and look back to lock her, noticed the spoiler was completely gone. I am not sure where it came off yet, but I have yet to...
