1 - 5 of 5 Posts
I noticed one of my rear subs was not working at all. and i was also going back there to switch the wires since they were wired wrong from factory.
One sub doesnt do anything so I unhooked it and added wire to the other side and tested it using the other subs wires and it works and sounds fine but now I need to find out why it isnt getting a proper signal...
I have stock HU and no amps other then factory.
Discussion Starter · #2 ·
OK so I forgot I did this when I first got the car last year..
http://www.g8board.com/forums/showthread.php?t=56654&highlight=stock+phase
was this basically the same thing as me going to the speaker and switching the wires or is this something different? and is it possible me doing this last year one of the connections I made came loose and that why the rear speaker isnt working?
it's probably working. it just sucks soo bad you cant hear it.
check your fuses and make sure the amp wasn't unplugged for some reason, just peel back the carpet.
Discussion Starter · #4 ·
Ok so I messed with it some more and now both damn subs are not working...I know this cause I cannot feel any vibrations whatsoever when the subs are hooked up...
I also checked the fuse on amp and fuse by footwell f2 both were fine?/??
1 - 5 of 5 Posts
