I'm changing the rear passenger lower control arm on my car and I'm stuck on the inner eccentric bolt. It's the last bolt to come out, but it's not going anywhere. I already took the nut and eccentric washer off the forward end, but the bushings seem to be frozen to the bolt that surround the arm itself. I can move the arm vertically, but the bolt turns with it. With a big breaker bar I can spin the bolt, but the bushings are spinning with it. I'm pretty sure it's not threaded and just needs to be pushed out, but there isn't any room on the forward threaded end to hit it with enough force with a hammer. I've covered it in penetrating oil and tried an impact, but no dice. Anyone have any tips for getting this sucker out? I don't have a torch either.
Here's a couple photos to help you get an idea.. The arrows in the third pic are pointing to the rear.
