1 - 20 of 27 Posts
Discussion Starter #1 (Edited by Moderator)
I maek mah avitar :3
I know the LTT is DI whereas our L67 isn't. I don't know if that makes or breaks an install of this caliber but I'll let others chime in.
This mod could apply to the VE Series II Commodore, I imagine, which has the LTT V6.
Pity that the G8 didn't get the LTT...
aside from maybe tweaking the fuel system side of this cant see how itd be detrimental(not sure if there was any adjustment, but lets say it needs a boost-a-pump... no biggy)
DI is more in depth from a tuning perspective, having to consider fuel lobes on the DI high pressure rail/fuel pump being a non issue on the g8 6 cyl. cars.
not sure what the factory injectors on the g8 v6 are rated too either but worst case scenario arent they uscar type injectors?(forgive me if i'm wrong i'm not overly up on the 6 cyl)
Not that its a big deal.. But the V6 is a LY7.. the L67 is the 3.8 that came in most GM FWD platform.. Just letting you know so you look up proper parts..
My buddy had a pretty nasty 1998 GTP with the supercharged 3.8.. 340 at the wheels.. the older holdens come with that engine.. would be like a grand nat.. be kinda neat
I just got a 1999 GTP. Eager to start working on that.
I know the owner of this V6 supercharged Camaro. He said that it will out run a stock SS Camaro.
When he showed me the article, I noticed the stock intake manifold, and with the issues GM has had in the past with plastic intakes, he said he is keeping a close eye on it to make sure it doesn't crack. He told me that the boost was limited to 8 psi, but also mentioned that the additional horsepower cannot be handled by the stock V6 clutch.
It does appear that he has a sleeper.
It is actually my car and the clutch is getting made now, will test the prototype soon, hopefully for the fall edition of Camaro Now. It has been flawless for over 7000 miles so far other than the clutch is getting weak. high 12 in the 1/4, traction and clutch limited. Setting it up to carve the road course now. Full 1LE suspension with some aftermarket upgrades too....
Discussion Starter #12
i dig it! sleeper for sure :D
tell us all about the setup, and for our v6 friends in this thread, talk about how you came into the kit, R&D and all that. Thanks!
Its actually a kit by IPF, you can google them, I wanted a kit that looked oem and performed great. I have been exptremely pleased with all aspects of the kit. It utilizes the Vortech V3 head unit
Facebook Moderator
Car looks dope! I am getting my hands on a Vortech V3 as well!
Facebook Moderator
hopefully ill be running next to you at G8 GONE! :D
hello hummer 1 any chance these clutches have been developed already and might you et us know who developed these clutches.
Do you believe these clutches will be compatible with the g8 v6 ly7.
thank you
Call RAM clutch company. I have had the clutch now for a year and it has been perfect. Hard use on the strip and road course with no slippage and engagement is great. no idea on the fitment, but if it works it is a great way to go.
1 - 20 of 27 Posts
