Last week I finished the install of my new brakes on the car. I really like them so far and am looking forward to putting a few miles on them and seeing how well they perform on the autocross course. They felt very nice after the bedding process.. pedal feel is great..
I had an issue with the right front Brembo rotor coming to me bent - so very slightly 0.0035 runout for about 3-4 inches of the rotor's circumference , but that was enough for some pretty severe brake judder. Rockauto was quick to stand up and send me a new one and took the return of the defective part with return shipping included. With the new rotor on all the judder went away.
First my part numbers and sources.. (prices from March 2013)
Rockauto -
Brembo floating 2-piece front rotors AC Delco 1771145/6 $290 each
Kore 3 -
DBA plain 4000 series rear rotors 42031 $232 each
Amazon -
Russel SS brake lines 692210 $136
Brass banjo washers AC Delco 21012386 $6
14mm drill bit BISRSD14.0MM $18
09 CTS-V 6 pot AC Delco calipers 172-2487/8 $334 each
10 Metric Bolts M14-2.0, 40mm B006HYFXIW $12
04 CTS-V 4 pot rear calipers (swapped crossover tubes)172-2308/9 $69 and $78
10 Metric Bolts M12-1.75, 45mm B006HYFUB2 $10
Permatex 24125 Ceramic Extreme Brake Parts Lubricant, 8 oz. $16
Hawk HPS pads HB649F.605 $125
Brake caliper pin kit Carlson H5843 $13
Hawk HPS pads HB194F.570 (trimmed pad) $96
Brake caliper pin kit AC Delco 18K1970X $16
2 liters ATE Super blue fluid 706302 $21
4 brembo vinyls B003ENA2EO $4
Hardbrakes -
Stainless 1mm thermal backing plates for rear pads TS-S-D0592 $44
(used to make up rotor being 2mm thinner than standard rotor)
Before and after photos to follow...
Rockauto -
Kore 3 -
Amazon -
Hardbrakes -
