1 - 10 of 10 Posts
Like to know when some of you had problems with your timing chain. At what kilometers or miles did you needed to replace it.
every village has one
There's a writeup on the forum here. Just use the search.
OGOC Member
It seems to be around the 130,000 km range
I've heard that oil changes should not be more than 8000 km's, some say 5000 with these engines.
OGOC Member
If you use a good quality synthetic oil,I can see 8000 or more, depends on your preference. But if you use conventional oil then yes 5000 kms.
Synthetic at 5000 could get expensive.
I do mine about 8000 kms
So you are using synthetic.
2006 and 2007 V6 engines timing chain will stretch no matter what, it's a well known issue that was corrected in the 2008 and onwards models.
But I heard that it still a problem, I guess with extended oil changes it definitely is a problem. Correct me if I am wrong but going with the olm is a no no.
OGOC Member
Yes I use Castrol titanium full synthetic.
OGOC Member
They will stretch over time no matter what. With 3 chains it's bound to happen.
1 - 10 of 10 Posts
