1 - 5 of 5 Posts
Ok so Im at the point I need drag radials and I just want to verify that this setup will fit without issue:
18X9.5 5x120 TSW Nurburgrings 40mm Offset / 7 Inch Backspace for the rear
with either:
Nitto nt05r's or mickey thompson et street DRs
285/40/18
and 18x8 (8in wide) up front will it clear the brembos?
Rears, yes. Will rub on dips or with weight in the rear, but since you're drag racing I don't suspect that will be an issue. I'm pretty sure the fronts will fit fine as well.
ok cool thanks
Dazed - Confused
I am running the same 18" 05R's on Beyern Multi 9.5's with 45 offset. I also have the same 285 Bridgestone on 19" Beyern Multi - same width and offset. They zinged only when I went thru a deep dip at an angle. Even so, I rolled my fenders as a precaution.
Problem with our fender lips as stock, they like to cut into the tire sidewall!.
ok im on coilovers on full stiff rears almost full stiff front.
ill roll the rears but i should be fine?
1 - 5 of 5 Posts
