1 - 3 of 3 Posts
My 2008 G8 turn signal lever makes a clunking sound, rather than the normal soft sound when it returns to the middle (neutral) position after turning right. The lever does not make that sound when it returns to the middle from the left position. It makes that sound both when I manually move the lever to the middle from the right or when it automatically moves after finishing the right turn
Thoughts?
Reads like there could be a malfunction inside the turn signal stalk. Remove the switch for further inspection. turn signal switch
All I did was remove the top cover of the steering column and reinstalled it and the clunking sound went away. I think the boot might have not been seated correctly or have shifting. I'll see if the issue comes back. Thanks for the support.
1 - 3 of 3 Posts
