I've done some searching through here and found a few different threads that are some what similar to my situation... but it's been inconclusive.
Recently the car, an 08 G8 GT, has been acting up with increasing frequency. The check engine light comes on during start up, car stuck in 2nd. If you clear the codes with the car running you can drive it normally, but upon restart -sometimes- it gets stuck in 2nd again. Sometimes a P0700 code populates with the U0073 code, along with a C0196-(xx) code that is a yaw rate sensor. The U0073 code is the only one that is consistent.
I've done the battery bolt fix that everyone likes to link to, sanded down/replaced the bolt on the chassis ground connection @ the battery-chassis, engine-chassis, and PCM/ABS-chassis. Issue persists.
Had the battery tested at AAP, came back as "better than spec" per the sticker.
Pulled major connections points apart and cleaned with electronics clear, let dry for a day then reconnected (PCM, ABS, Transmission 16pin, and the multipack connections near the fuse block and brake booster). Issue persists.
I've seen a few threads point to the valve body, or TCM being faulty but that doesn't seem to be consistent with 'clear codes, drives normally until restart' type condition.. anyone have experience with something like this before?
