1 - 9 of 9 Posts
I was way off...Its 44in lbs on first pass , and then 89 in lbs on second pass.. I suppose you should probably have the sequence too
Brace Bolt - Engine Front Cover M12 65 Nm (48 lb ft.)
Brace Bolt/Ball Stud - Intake Manifold M6 10 Nm (89 lb in.)
Engine Cover Ball Stud 9 Nm (80 lb in.)
Tuning Valve Bolt 10 Nm (89 lb in.)
Upper-to-Cylinder Head Bolt - Long 23 Nm (17 lb ft.)
Upper-to-Cylinder Head Bolt - Short 23 Nm (17 lb ft.)
Upper-to-Lower Intake Manifold Bolt 23 Nm (17 lb ft.)
Throttle Body Bolt 10 Nm (89 lb in.)
Install the intake manifold assembly (2).
Notice: Refer to Fastener Notice (See: Service Precautions\Vehicle Damage Warnings\Fastener Notice) .
Important: Tighten the intake manifold to cylinder head retaining bolts (1) in a circular pattern starting at the center (long bolts) and moving outward.
Install the intake manifold to cylinder head retaining bolts (1).
Tighten the bolts to 23 N.m (17 lb ft).
1 - 9 of 9 Posts
