Does anyone know where I can get a new plug? One of the pins in mine is messed up or broken. Not getting any signal out of the harness, but I am out of the amp.
-LPM
Thanks for the info Swargolet! I might have to see if I can just get one from a wrecked car.I believe THIS is it, but I'm not certain. That connector type is called 'multilock', so if you search around for 12-pin multilock connector or something like that you may find it.
Either way you'd be better off just replacing the one pin. I found a PDF on how to do it and it seems to be for that exact connector too! LINK
EDIT: And I believe the manufacture is called AMP
