41 - 60 of 92 Posts
Ya.. im kinda scared of the oiled filters since my buddy had one on his car and th motor went bad way before it shudv and th mechanic sed it ws due to the oiled airfilter. And i drive alot of gravel.. i wudnt mind so much if i didnt drive gravel bt id really like my car to live its life to the fullest
OGOC Member
Discussion Starter #42
I hear ya, if too much oil is used then it could affect it. I have always had k&n. I just don't oil the crap out of it. But if you feel better with a dry one then go with it.
Well i cant really tell you how it helps cause after i got 3.27 installed, i was waiting on the tune for the trans from Will. Then my timing chains went to ****.. So car is in Dumb Mode from that.. Have never had it running fully yet with gears. Now its winter and the car sits away from snow and salt. Going to be Spring before i fix chains and see how it does..
Oh man thts the real sh*ts there. Good luck with getting her back up and running again! Did u ever take note of how much your rpms went up with those lower gears? Like cruising at 60 mph what were ur rpms?
Hey what did you had to change was it direct or you had to mod it and was it ss 3.27 from Camaro ? I'm curious doing that but just don't wanna mess with it if it's not direct
Hang in there Les. I went on a dyno this spring down in Dayton that sent me packing back home with some numbers that did not look that great. Other guys posted that knew that dyno's characteristics and they brightened my day leaving me at 332 HP to the wheels with the correction factor in place. That was before headers so I will be heading down to a local dyno to see what I've after getting the headers +retune on last May.
OGOC Member
Discussion Starter #48
I think it was only like 200-300 rpm at 60
I only thing i had to swap was the yoke.. The V6 has a smaller bolt circle than the V8. Do yourself a favor and put a new pinion seal in at that time. Mine leaked a little till i changed it. I used a camaro ss diff and replaced seal with camaro seal.
Numbers are a little lower then I anticipated they would be.
OGOC Member
Discussion Starter #52
All Dynos are different. You can safely add about 10hp to these numbers. Either way were only going to get so far with bolt ons. There are things in the works now to upgrade it a bit more.
The dyno day, the other guys I talked to said that it seems off a few hp, will do another dyno in spring at different dyno.
OGOC Member
Discussion Starter #54
Other things. Not the ecm yet lol. Just looking at options at the moment. He will keep me informed. It's a trial and error kinda thing.
Agreed, you can only get so far with bolt ons. I still expected a little higher based on the mods you have.
I think youre correct that the dyno was off by quite a few Hp.
I look forward to the future dyno results and will be getting the tune this spring. For now my pockets are recovering after the new catback
RSP Motorsports has a $$$$$ dyno that they say is dead on. Since I am done modding on the engine side it's time to lay down some coin and really see what this setup is giving me. Many dynos seem to have correction factors floating around so to me those ones are now a way of making noise while the car stands still. Don't get me wrong, it is a hoot to hear what sound the exhaust makes under full load and all that. It is going in tomorrow at 10 AM in some nice cool air. I will report later.
OGOC Member
Discussion Starter #58
Hey frank let me know details on the dyno. I can try and get it in before I store her for the winter.
RSP MotorSports has an AWD Dyno and they service high end Eurocars.
The process is 2 hours long for just a power assessment but they are willing to tune if you come up with the coin. It is a half million $ dyno and I saw Bentleys, Porsches , Merc & Lexus metal out front. They are in Kilworth just west of London. Is there a high end dyno in Mississauga that's closer to you? Don't know if you want roll out this far but if future plans go right, I would still like to host a meet out this way.
OGOC Member
Discussion Starter #60
Well don't need it tuned. Jst another run. I'm in Oshawa Frank, but London isn't a problem. How much to just do the dyno there. 2 runs?
41 - 60 of 92 Posts
