1 - 20 of 39 Posts
Well, I just ordered a Vararam, HSRK, and radiator cover which will be an upgrade from my homemade intake that I did while I saved for a nice setup and got my exhaust finished. Now onto the question, has anyone done a LS7 MAF with the Vararam yet? I know the stock MAF will flow more then enough for me even with the camshaft upgrade I have planned around summer time but is it a good upgrade to do in preparation for it or is it just a waste of time since the OTR design is a straight shot and not really worth the extra tuning time required.
Thanks guys!
Super Moderator
Thanks guys!
I am! Better throttle response is what I've noticed.
Got any pictures? How much was your MAF tables off by?
Sub I have the vararam in and I have a ls7 under my bed waiting to be installed when I go for tune
Super Moderator
No pics, the car is in storage still for the winter. Hopefully will get it out this week.
As far as the MAF tables, I have no clue... Rick Crawford adjusted everything after I hooked it up. He would be the person to ask...
Discussion Starter · #6 ·
Did you have to buy anything for it to work with the vararam or did all the pieces work together?
I'd be interested to know about fitment issues as well with stock and aftermarket intakes designed around the stock MAF.
An LS7 MAF sensor and 4" housing is on my shopping list as per Rick C. I've heard lots of people say the throttle response is greatly improved, and I assume the extra cross-sectional area of the 4" housing improves flow potential in the most-restrictive section of the intake tract.
I have one for sale if anyone us interested. That exact one never installed still in box
I like mine. Throttle response it great and I believe it gave me some extra power. Figure about 10-15 hp as I installed it along with headers. It dyno'd about 10-15 hp higher than most others. If you get the aluminum one, I suggest getting it coated. That thing will soak up some heat if not. ImageUploadedByAutoGuide1365861779.359807.jpg
google spectre 9705 and go to amazon, then down at the bottom will be a frequently bought together option and it has the maf sensor.
Do not change the MAF sensor on the car. It is not a restriction until at least 550rwhp and the change will affect your transmission line pressures on an automatic car. There is no power to be gained if your car is properly tuned with the stock sensor. People are running 600+rwhp with the stock MAF sensor on FI applications - if there was really a big gain don't you think they would make the change?
Super Moderator
My car idles better and throttle response has improved when I switched to the LS7 card.
Advanced Member
The Vararam and a 4" MAF setup is almost perfect. I can log 99-100 kPa on a 1/4 mi run. The stock MAf with a velocity stack is good but not as good as the Vararam. Just got to keep the filter lean.
I found the 9705-Aluminum Tube 4" O.D. Maf Adapter Kit but where do I buy an actual ls3 or ls7 card sensor and what about the screen inside the housing? As I stated on the other thread im having fitment issues with my larger 102 t.b. and my AFE cai because the mouth of the 102 bigger (4.25in) and the cai is (4in) and I barely got the coupler over the mouth of the 102 but the elbow of my AFE slides right through and im stuck and don't know what to do? I even called about the rotofab 102mm cai but the maf housing isn't quite 4in but is bigger than stock but does not come with a sensor so id have to use the stock one or find a sensor and I again have done some reading but not sure where to buy that or adapter harness. CAN SOMEONE PLEASE HELP AND LEAD ME IN THE RIGHT DIRECTION or JUST TELL ME WHAT TO BUY!! Being new to all this has caused me to get stuck and its making my brain hurt.
Card MAF=Amazon
Straightener - see post 15
1 - 20 of 39 Posts
