How the hell are you spinning like that on dry pavement? I try daily and can almost never get the wheels to break loose. What RPM are you power-braking to? Is it the LSD that's letting you do that? We have basically identical performance setups otherwise...
I donno it just does lol. All i do is stage and if it dosen't go right away i release a little break till it goes. i can break loose from a dead stop too, not crazy like tho. and i can get sideways around cornors too in manual mode.I dont think the lsd made it so i could, i used to do one wheels with the stock base diff and 245's. I never thought i'd be able to do a burn out with 285's on back too, but i proved that wrong
Good deal on the LSD, thats what the V6's should have came with. I understand the cost savings. In terms of added safety and usefulness the LSD is a must. There is a handfull of times where I've kicked the car sideways from not even an agressive take off in the rain with the ESC on.
While the V6 does not match up to the GXP or GT horsepower wise, that does not change the passion owners have for their G8's.
Why not start our own registry as well, following much of the same layout.
My info:
Year: 2009
Colour: Panther Black Metallic
Options: Sunroof, Comfort and Sound...
Hello everyone! I have recently changed out my 3.6l engine for another used 3.6l. I have tested the battery, checked all the electrical connections. The starter tested good and the starter relay is good. The issue that I am having is it has a very weak crank if I'm lucky maybe one rotation and...
I currently have a v6 G8 that I'm trying to swap into a 5.3l. Is there any major differences between the v8 and v6 g8s that could make this swap more difficult ?
So last weekend I just had my overkill tune installed (thanks to a vary big help!!) and thought I would write a little review.
Right off the bat you can feel the throttle is more responsive the faster you push the more it goes. But at the same time it isn't enough sensitivity to hurt anything...
Hey fellas first time posting on here but I’m having some issues with my G8 in which the key is stuck in the ignition. Figured this could be the place to help figure it out before I take her into a dealer/shop.
Just bought the car a month ago and not entirely familiar with it yet.
Then being...
