This started happening a couple days ago I cannot figure out what's causing this. But this is REALLY starting to bug me.
I have this rattle noise that almost sounds like an old trailer hitch, coming from the right rear area underneath the car when you hit bumps. I crawled under the car as much as I could yesterday (no lift or jack) and couldn't find it.
However, there is one spot by the right rear wheel where the exhaust definitely nudges a spot on the uni-body if you give the exhaust a good whack with the palm of your hand. It's too close, and I will adjust it. But the sound is totally different. It's not the same tone as the rattle/shake I'm hearing when the car is moving.
Is there anything in that area of the car that could cause this? Aside from the exhaust, I'm out of ideas. Cause I have a feeling that when I fix the exhaust clearance issue, the problem isn't going to go away. Thanks.
