1 - 11 of 11 Posts
Made the mistake a while ago to use a paste type leather cleaner/conditioner and, over a year later, I still have the evidence in the holes. I have tried the shop vac and it worked somewhat. Have considered a small drill bit to clean the holes, but very hesitant to do that.
Now, I only use the pre-moistened wipes, but would love to use a good quality product on them.
every village has one
I like the Turtle Ice premium interior care spray. I've used on everything inside.
I still use Lexol occasionally, but when I want a quick wipe down, I use the Ice.
I use the teeth of a comb to perforate the holes. Works great. And a nice spray of 303 Aerospace to condition.
Adams doesn't leave crud in the holes.
But if you do have some paste still stuck in them, I would think that a toothpick would get it out. ?
A toothpick might do, but I thought spinning a tiny drill bit would pull stuff out of the holes instead of pushing it around.
I wouldn't use a drill on my leather seats. You still have to push the bit through the hole anyway which would just push the goop in. Just use a comb tooth, the leather isn't that thick so it just dissipates into the foam.
No drill. Toothpick but will take a while. I use lexol cleaner and conritioner. Happy. Try a soft brush. Softer then a tooth brush and just try cleaning it a couple times. You use warm water to help open pours . Spray cleaner on with warm ,don't wanna go to hot water ,and scrub and clean leather. Don't need to use to much elbow grease . Then condition. Its like 16 bucks or so for a bottle of both at Walmart. My old job used this stuff and that's how I learned of it and used it. Good luck
****cray
meguiars leather conditioner cleaner in the spray bottle. it does
come out thick, but will wipe off, and doesnt stay in your hole.
use it on both the g8 and the gto.
Discussion Starter · #9 ·
Thanks, all! The responses are appreciated. Looks like plenty of good info to clean 'em up good.
1 - 11 of 11 Posts
