1 - 20 of 40 Posts
just trying to see what others are running for their wheel size and offset. pictures of how your car sits would be greatly appreciated!!! the wheels i want to put on my car are 20x9 +35 offset in the front and 20x10.5 +42 offset in the rear. i'm also lowering and having the finders rolled as well!! HELP ME PLEASE!!!! this was sooo much easier to do with my tahoe on 26's!! :comp:
The set up you want will fit very nice with the fenders rolled
My new set of wheels is pretty close to what you posted
Discussion Starter · #4 ·
Ew, that is an ugly stretch on that rear wheel.
20x9 +35 in front will fit fine, what size tire?
20x10.5 +42 in the rear is gonna be tight, even with a roll. Again, something like this works with a undersized tire though. Not my cup oh tea, but to each thier own.
Discussion Starter · #7 ·
yeah i know on that tire stretch is not what i want!!! or then what about
20x8.5 38 mm or 40 mm for the front
and
20x10 45 mm or 48 mm for the front
I want a offset that will have the car looking the cleanest once I roll the fenders and lowering it! also, I would like to thank everyone for their input!!!
I assume on that second fitment, you meant rear :)
20x8.5 +38 or +40 would work just fine.
20x10 +48 would be great, and should fit with a nice flat roll.
19 x 8.5 +23 (5mm spacer)
19 x 9.5 + 25 (3mm spacer)
245/35/19 all round, rear guards rolled to within inch of their life. Bumper bracket trimmed.
No scrubbing, rear clearance is very very close but clears.
your proposed setup depends all on the tyre you choose, rear will be close with a 265, but probably not with a 285 etc
Discussion Starter · #10 ·
these are the tire sizes being suggested:
Front Tires
245/35/20
Rear Tires
275/30/20
Sounds like a good pairing.
If possible though, I'd try for 255 and 285. A 10" wheel deserves a 285 or 295 if possible.
Discussion Starter · #13 ·
any pics???
20x9 +35 front and rear, 275/35 tires. They rub on stock suspension even with rolled fenders. I am planning on pulling out the grinder this weekend and taking the lips down a little bit. Hope that helps
Discussion Starter · #16 ·
so which would be the best offset for the front :20x8.5 +38 or +40
You're only talking 2mm, and either will work out just fine. Might depend on what you have in back too, to help with the stance.
However, I'd go with the +38, as mentioned above. Every little bit pushing out the fronts looks good in my opinion.
Discussion Starter · #19 ·
ok I called the wheel company....and they stated that the wheels offset that will tuck(with a fender roll) that fits my car is the 20x8.5 - offset 35mm front and 20x10 - offset 40mm rears..... this doesn't look close to what everyone else with G8's are running....but i took the manufactures word and ordered them.,,but does that sound right for the offset??
understeer
10" et40 will not tuck...my 9.5 et 40 did not tuck.
1 - 20 of 40 Posts
