1 - 9 of 9 Posts
I plan on doing a full service on a car that I just purchased. 09G8GT with a hold of the original owner today but if I can’t just wondering should I use full synthetic oil in the car I know the myths about oil will cause leaks if I run synthetic but those messages were for the old synthetic oil where is new synthetic oil do not have all the additives thatI plan on doing a full service on a car that I just purchased. 09G8GT with 200,000 on the clock. I’m going to try to get a hold of the original owner today but if I can’t just wondering should I use full synthetic oil in this car I know the myths about oil will cause leaks if I run synthetic but those myths were for the old synthetic oil whereas new synthetic oil do not have all the additives that made seals leak. Just wondering if I should switch I mean I doubt it’s going to hurt the car in anyway. Also the car had a code for loyal pressure but after using a scan tool with the car fully hot the oil pressure was 20 at 600 RPM which I don’t think it’s all that bad just wondering what weight oil I should run if I switch to synthetic.
Proceeding responses should be interesting to say the least. Would use a good quality 10W-30 synthetic blend or full synthetic motor oil. Personal preferences are Castrol or Pennzoil high mileage.
Reactions: jonup
Next oil change, do the 10W-30. You should see the hot idle pressure go up to 25 or 30psi. Safer pressure for spirited driving. Synthetic or regular.
Reactions: jonup
258k miles here, still using synthetic 5w30, might give the 10w30 a try next oil change. Started car this a.m. at 25 degrees outside temp. Very quiet, with no valvetrain noise what so ever.
Local quick change oil shops are interesting after having to use a breaker bar to remove the oil drain plug. Won't even get started on removing the oil filter. Perchance it's merely standard industry practice albeit gesh.
201k and whatever synthetic in 5W-30 is available. I do like the AC Delco filters.
Reactions: DE DORSETT
I use what the owner's manual recommends.....5W30. I'm at 191K and I switched to full synthetic around 50K. Still rides like a charm. As far as brands, any will work as long as it meets GM standards. I usually go w/what is on sale. And usually, the NAPA brand is on sale.
1 - 9 of 9 Posts
