1 - 5 of 5 Posts
Got a guy who has a set of gun metal vmr vb3 for sale. Of course I'm not to sure the stock wheels fitments but would gues 5-120 19x8.5 et 40 front and 19x9.5 et 45 back. He has 5-120 19x8.5 et 40 front and 19x9.5 et 22 back will they fit? Can I run spacer? Not sure how to approach and see If its worth it.
Stock size is 19x8 +48 all around. The VB3s that you're considering are fine up front, but too low an offset out back. You'll rub big time, especially with 9.5" wheel. Check out the "Will it fit" sticky for all kinds of wheel and offset info.
Karlhungus spacer won't work I mean is a awesome deal. Not sure if spacer will work
Spacers will just cause it to stick out even further causing the issue to be worse.
Yep, adding spacers will only push the wheel further out.
1 - 5 of 5 Posts
