My car is not here at this time to try to see *how* those 3 rubber sealing strips actually attach. I can see/read, that they are installed down both sides an the across the top, to seal up the gap that must exist between the radiator an condenser after installation is complete. They obviously want all the air that passes thru the condenser, to continue to pass thru the radiator (with the least amount of that air escaping out thru those otherwise, open an less restricted areas. Looks like you would have to visualize how they were attached at this time. *IF* I can remember to look at my car later, maybe I'll be able to see exactly *how* those 3 rubber pieces were secured an to what surface (as in radiator support structure, radiator, or condenser, etc).
