Which spacers to get on 18’ gt stock rims
734 Views 6 Replies 6 Participants Last post by  kevtheo1191
Hello, well I never put on spacers so don’t have much knowledge but I’ve seen g8s in person with spacers and one with offset rims. Either way looks absolutely amazing, now this guy posted on forum 15mm front 20mm back. Now I’m just wondering if anyone has any links for the spacers that fit these exact sizes and are good quality ones. As always appreciate you guys
Tire Wheel Automotive tire Light Motor vehicle
See less See more
1 - 7 of 7 Posts
When I first upgraded my calipers to Brembo, I used 19mm for my stock wheels, front and back to clear the calipers until I replaced the wheels.
I have seen many sets of different sizes out on eBay.
5
I did 20mm all around on my stock 19s, also fits fine for 18s. One thing to keep in my is tires, as some stick out from the wheel lip more than others. This is with Firestone Indy 500s at stock size. Close to flush without rolling and easily clears Brembos. Have always bought from this seller on eBay with no issues:
Wheel Automotive parking light Tire Car Land vehicle
Wheel Tire Automotive parking light Plant Vehicle
Automotive parking light Tire Car Automotive tail & brake light Wheel
Tire Wheel Car Vehicle Land vehicle
Wheel Car Automotive tail & brake light Vehicle Land vehicle
See less See more
Yup, those are my photos. I have the spacers in there boxes. One item that no one mentions is the diameter of the spacers to match the rims hub. The 15mm matched perfect. Will post the photo later so you will know what to order from Amazon.
Reactions: 1
Eibach hub centric wheel adaptors look them up for a 2010 Camaro 20mm I believe will give you a flush look you want. Clean all mating surfaces very well and torque to spec. Then install wheels. you will need to take the leading tip of the existing studs.
Any update with what to order? Thanks
I would think most spacers are made to about the same diameter but I've only ever bought from one seller for multiple vehicles.
1 - 7 of 7 Posts
