1 - 7 of 7 Posts
Im clueless on where and what TPMS will work with our cars! I found this one on amazon that i thought would work!
[ame]http://www.amazon.com/VDO-SE10001-REDI-Sensor/dp/B004SH5J34/ref=au_pf_ss_1?ie=UTF8&Make=Pontiac%7C52&Model=G8%7C6613&Year=2009%7C2009&carId=&n=15684181&s=automotive[/ame]
Or
[ame]http://www.amazon.com/Dorman-974-009-Pressure-Monitor-System/dp/B001UCB1C8/ref=au_pf_ss_2?ie=UTF8&Make=Pontiac%7C52&Model=G8%7C6613&Year=2009%7C2009&carId=&n=15684181&s=automotive[/ame]
They say both will work. The Dorman model even shows a list, that this unit is a substitute for. If any of those P/Ns listed, currently work in the G8, I think your good to go. Not to mention, they have a lifetime warranty on that one.
Discussion Starter · #4 ·
Do i have to buy a tire pressure monitor valve replacement kit if i order the dormans in my OP?
No, just valve stems made for TPMS sensors. They are longer than the regular ones and have the extra screw portion on the bottom of the stem so it will mate up to the sensor.
Discussion Starter · #6 ·
...will they work and is this all i need for the TPMS to work?
CHEVY GM TPMS SENSORS *20923680 - 13586335
any GM > 25920615, 20923680, 15922396, 25799331,25799331 and most 315MHz TPMS...
Yes they will work and this is all you need. Price is pretty reasonable too and hopefully you read this part at the top of the screen. This seller is currently away until Apr 08, 2013. If you make a purchase, there may be a delay in processing your order.
1 - 7 of 7 Posts
