2009 Pontiac G8 GT, Texas speed stage 1 cam, built valve train, built transmission, H&R Coilovers
So I have just finished putting the engine back in my car, and everything is working beautiful except for the wipers. They worked for a few days, but then slowly started to intermittently work, and now nothing. With the KOEO, I can hear a buzzing sound from my fuse block when I try to turn the wipers on. I pull the relay, and the noise goes away. I switched relays and fuses, nothing. With the wiper relay pulled it shows an ABS fault on my DIC. One time driving the car I was spamming the wipers to see if they would work, and an ABS fault popped up and the car downshifted and freaked out a bit. I'm guessing I have a short between a wheel speed sensor wire and the wiper motor wires since they are in the same loom. Wanted to make sure before I started tearing into it, any info appreciated!
